3.22 x86 ssh bug?
Hi Tikpeople!
I try ssh login with user password length >= 32 chars and don't work! (x86 arch)
Is a bug?
If I disable ftp privilege from group user this bug not occur, only if privilege ftp is enabled. :open_mouth:
With wrong password returns me:
admin@192.168.1.1's password:
Permission denied, please try again.
With correct passwords returns me:
Login failed, incorrect username or password
Login:
I belive that's a privileges error.
I can confirm this bug. The system is a 3.22 mikrotik on a Pc Engines alix6b2 board.
/user set system password=01234567890123456789012345678901
/user pr detail
Flags: X - disabled
 0   ;;; system default user
     name="system" group=full address=0.0.0.0/0
/user group pr detail
 0 name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,
                    sniff,!ftp,!write,!policy
 1 name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password,
                     web,sniff,!ftp,!policy
 2 name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,
                    password,web,sniff
Setting the password to 32char i cannot login with ssh [telnet,winbox,mac-telnet yes i can] with user system:
system@192.168.1.10's password:
echo: system,error,critical login failure for user system from 192.168.1.217 via
 ssh
echo: system,error,critical login failure for user  from 192.168.1.217 via ssh
Please look at the last line of the log… there isn’t the name of the user.
Anyone else have the same problem?
It’s strange… :open_mouth:
we will look at this. but why such long password ? :slight_smile:
For security reasons. It’s a client requeriment.
Thanks a lot!
I think it’s much more secure to use certificates:
http://www.mikrotik.com/testdocs/ros/3.0/admin/ssh.php
Sure! that’s more secure!! :smiley: but only I need large passwords
to be honest - it does not make any sense first you say, that you need very very safe and secure, so you are using password, when you have more secure option - you say, you do not need that and you need less secure solution. Make your mind - what you need, more secure - use certificate, less secure - password. and in last case any password longer than 32 symbols does not make sense, ask any security expert out there about “feature” where password is longer than that.
  1. We will investigate why SSH doesn’t work with long passwords, don’t worry about that.
  2. I think such long password is not possible to remember, and user will be forced to write it down somewhere, decreasing security ~-0 :slight_smile:
Yes it’s difficult to remember the password but it’s my client requeriment… :open_mouth:
But this is a bug and I think it’s a error in privileges control. With ftp privilege disabled then works perfect.
Normis, to report other critical error, which mail I have to write?
Sorry for my english…
write to support with steps how to reproduce the bug
Ssh bug (x86 arch) still in v3.23.
Any news?
