3.24 API->disconnect
My problem goes like this. Im using php API to manipulate some data on my MT’s using website. All was ok until now. On MT’s with new OS (3.24) after disconnecting, the connection remain in “Active Connections” even though I use disconnect() function. Does anyone have a solution for this problem?
seems like a bug. I have that problem too. MT Guys, is this known problem, or we should send supout? =)
no need, fix will be available in 3.25
OK. Thanks
I’m using 4.11 and still having the same problem… This just was resolved?!
only in v5, unfortunately
Please! MT programmer, create patch for this problem in 4.x version. 4.17 has still bug in logout from API connection (“/user active” is a very very long list). Very please …
they won’t backport it, unfortunately. v5 is current ‘stable’ version
