Can not be certified to enter the settings
Hi. Please check →
(in WinBox)
IP → Services → www - Allowed From should include your IP address or be 0.0.0.0/0
I hope this helps. Good luck.
there is a bug on x86 arch - webbox is not working. Will be corrected in next release. Just hang on.
webbox seems to be buggy in 493AH as well,
i have several ether interfaces bridged together in different bridges, but i viewed (ONLY VIEWING) those interface using webbox, they turned all interface to bridge1.
regards
Please hurry with the next release! Is the next release going to be in “legacy stable” or just “stable”?
Doug Shove
Dear Mikrotik,
There seem to be some seriuos bugs in v3.25
Brigde setting & wireless interface settings were suddenly gone, back to default.
Other settings such as ip address & routes are still there.
Happen to us twice of those upgraded RB 411A
and RB 493AH.
We’ve upgraded most of our RB somewhere else, hoping there’s no ‘back to default’ to other units!!
Sending supout.rif to support!
Settings are sometimes lost in upgrade, yes. This happens when upgarding from v 2.9 to v3 mainly but could happen more often… ?
Webbox also seems broken in 3.24 on x86 hardware. It is working on 3.17 x86 though. Anyone know what exactly was broken in webbox ?
Nope, Mikrotik you’re wrong. It’s not fixed in 3.26 I checked. When is it going to be fixed?
