I have just discovered that after upgrade of a link made on 1Ghz Celeron small factor boards the link became unstable. When I checked all the settings I discovered that the system clock on one of the boxes runs too quickly (observed using winbox System → Resources). The seconds were increasing about 3+ quicker than the real time.
The configuration is rather simple one - EoIP based link between two places.
When I deleted the EoIP interface and rebooted the box the time speed was OK. After a while I added the EoIP settings and enabled EoIP in bridge the time went crazy again. The link is part of a circular topology where RSTP on cisco switches is used (no (r)STP alllowed on Mikrotik boxes) and there are VLAN tagged frames forwarded through the link (the boxes have no VLAN settings - their management IPs are in native (untagged) VLAN)
There were problems with running wireless scans and frequency usage too (scan started but ended with error after a while). The problems disappeared after reboot.
3.28 x86 ROS used with Wireless-Test package.
The link was happy for long time with 3.17 and worked perfectly.
Anyone seen such behavior? Is there a bug in x86 version of ROS 3.28 or is it a problem with motherboard or so?
Regards
