3.30 vs 3.20 Queues
I have working Queues on 3.20 x86
when i’m updated system to 3.30 x86 my working queues don’t work, now i have 2 problem , i have deleted all queues & all firewall/manage/nat rules.
I have high pings to my GW and other hosts!!! and packet loose 5-10%
Tx/Rx - 200Mbit/200Mbit
pps ~ 35k-40k
system load 35-40%
where is problem?
Simple queues do not work with Xen package. Do you have it installed?
no i have not installed this package,
problem was solved with packet loose! (was in PCI Intel/PRO 1G network cards) Intel PCI-x dual port is working good now
queues not work propertly
please post more details (config, etc.)
Looks like there is some bug or change in 3.30 queues.
After executing command
/queue tree set queuename max-limit=xM
packet mark attribute disappears.
/queue tree set queuename max-limit=xM packet-mark=somemark
instead works ok.
Maybe you have the same problem with simple queues - packet marks are gone?
Yes me too.. V 3.30 on RB 750 and RB 433
the traffic is not counted and not appear in simple queue when i set to ‘unlimited’ limit.
Fix please..
‘Unlimited’ is a default value. If all other queue properties are also default values the queue will not take effect since it wouldn’t do anything, as per the official documentation.
Post such a queue that isn’t counting packets if you think that doesn’t apply to your case.
zulhanif, simply change at least something: for example, set type to ‘default’ instead of ‘default-small’
Oh..thanks..it work now..thanks Chupaka
