Hi, Im trying to implement a request from a client.
His setup
Main Office:
RBD52G-5HacD2HnD
Fiber router in bridge mode so external IP is on Mikrotik WAN (eth1) 185.83.x.x
LAN IP : 192.168.92.1
Office1 :
RouterBOARD 941-2nD
Internet provider is a WiSP so eth1 is a 10.0.28.x address from external SXT
LAN IP: 192.168.98.1
Office2:
RBD52G-5HacD2HnD
Fiber router NOT in bridge so eth1 is a 192.168.1.x address
LAN IP: 192.168.94.1
All standalone networks and internet working perfectly.
Main Office is running a PPTP Server
Office1 PPTP client connected and Local IP 192.168.92.2 and Remote 192.168.92.3
Office2 PPTP client connected and Local IP 192.168.92.4 and Remote 192.168.92.5
Main office added static route
add distance=1 dst-address=192.168.94.0/24 gateway=192.168.92.5 pref-src=192.168.92.4
add distance=1 dst-address=192.168.98.0/24 gateway=192.168.92.3 pref-src=192.168.92.2
Office1 added static route
add distance=1 dst-address=192.168.92.0/24 gateway=192.168.92.2 pref-src=192.168.92.3
Office2 added static route
add distance=1 dst-address=192.168.92.0/24 gateway=192.168.92.4 pref-src=192.168.92.5
All seems to be connecting and pinging correctly BUT… the client needs to be able to RDP from a PC at Office 1 & a PC at office 2 to his main PC in the Main Office
Thats it he has no other requirements like printers or anything.
From every side I can ping all 3 routers can ping each other but one PC cant Ping another PC (ie office1 PC cant ping Main office PC)
What am i missing ?
And should I be doing it a different way?
I have considered using VLAN but Ive spent days going through various examples and cant get them to work properly either?
Is this a correct example to use an eOIP ?
Any advice would be gratefully appreciated
