3 devices, one network
Hi all.
RouterOS n00b here.
Hardware:
1x CRS125-24G-1S-2HnD-IN
1x CRS109-8G-1S-2HnD-IN
1x CRS210-8G-2S+IN
4x Mikrotik 1.25Gb/s Single.Mode SFP 20KM
2x pre-terminated 100M fiber optic cables.
I was hoping everything would just work, and all i’d have to do is disable dhcp server on the two devices. Ok, obviously that was a fail.
S1 will sit in a little closet with customers server plugged into it, and two fiber connections coming from S2 and R1 located elsewhere in the building.
I guess if this was a cisco router and two switches, i’d just have to setup the SFP ports as trunk ports bam job done. But in RouterOS, I’m lost.
I’ve been digging around for a couple hours, googled, asked on IRC (probably not the right questions). I’m stuck.
What would be the best way to configure this?
How do I configure the SFP ports so they are all trunk links?
Any advice, clues, direction would be Very Much appreciated!!!
Please help.
Thank you!!!
Edit:
CRS210 shows both SFP ports link as active and running. with leds under the sfp ports ON.
CRS125 and CRS109 show SFP ports as “no link” with LEDs OFF.
You mention trunks, are you running multiple VLANs, or is this all just plain single LAN and S1 & S2 are operating just as simple switches without any router functionality?
Plain simply LAN, with s1 and s2 operating as switches.
so little update, somehow i got the crs125 and crs210 communicating over sfp. but the 109 won’t get it up for some reason.
Will have to play with it some more, maybe reset to defaults.
Well…
According to our supplier,
the CRS210 has two 10G SFP+ ports.
And only one of these ports is configurable as 1G connection, but the other only as 10G.
Right off the Mikrotik website about the 210:
two SFP+ cages for 10G connectivity (first port supports 1.25G/10G modules, second port only 10G modules)
Looking at the website, it looks like the 109 and 125 are 1Gig only, so you have a problem!
Don’t think I have a good solution except to use a media converter to connect your fiber to an ethernet port on the 210 rather than fiber into an SFP port.
I’d also strongly advise against “Mikrotik 1.25Gb/s Single.Mode SFP 20KM” on such short distances.
You will eventually blow the SPFs, unless attenuates are on the cables.
Thanks for the tips and advise.
Can’t we turn power down on these sfps?
Regardless, after swapping the 210 for a 112, I have a different problem now.
And a bizarre one at that.
Settings seem to match up between ports, and what not. I don’t understand why this is happening.
