3 ethers 3 networks 2 gateways - help me out here
Hi
I have 2 ISP's (1 adsl 1 wireless) that goes into 1 RB750. I want this RB750 to be a failover and also route traffic to 3 servers only via ADSL (gw2). I have been able to get the fail over working by setting the default route of ISP 1 gateway 1 to distance=1 and ISP 2 to distance=2. So if i take out ether 1 traffic is routed via ether 2 which will serve as gateway 2.
RB750 IP on Wireless 192.168.3.59 - eth1
RB750 IP on ADSL 192.168.89.1 - eth2
RB750 IP on internal network 10.0.0.254 - eth3
The dhcp is set on eth3. I am getting IP's, but cant the network connecting via eth3 to get on the internet, but the other 2 get there fine and the traffic I have routed to go via gw2 works and gw1 takes care of the rest.
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.3.1 1
1 S 0.0.0.0/0 10.0.0.254 1
2 S 0.0.0.0/0 192.168.89.2 2
3 ADC 10.0.0.0/24 10.0.0.254 ether3 0
4 A S 41.185.18.178/32 192.168.89.2 2
5 A S 54.247.165.221/32 192.168.89.2 2
6 ADC 192.168.3.0/24 192.168.3.59 ether1 0
7 ADC 192.168.89.0/24 192.168.89.1 ether2 0
8 A S 204.232.159.59/32 192.168.89.2 2
Cant get the AP that is the 10.0.0.254/24 to connect to the internet, not sure how to assign a gateway to it as its already in use
Make sure you masquerade NAT rule is correct. Also trace-route might help you to diagnose where the problem is.
