3 Internet Interface + 1 LAN (similiar to load balance)
hai,
i want to NAT’ed all of my local traffic to these 3 internet interfaces (WAN).
but i don’t want to load balance them.
  1. WAN1 = for email only (TCP port 25 and 110)
  2. WAN2 = for web and FTP (80, 8080 and 21)
  3. WAN3 = for others (p2p, messenger and others)
Question:
  1. Could i do the NAT through these 3 interfaces based on port (not balancing)?
  2. What is the different between using connection-mark and packet-mark?
    Hypothesis:
    i’ve ran several ideas (not implementing it).
  3. in the mangle (ip firewall)
    add chain=prerouting protocol=tcp dst-port=110 action=mark-connection \ new-connection-mark=email passthrough=yes comment=“” disabled=no
add chain=prerouting protocol=tcp dst-port=80 action=mark-connection \ new-connection-mark=web passthrough=yes comment=“” disabled=no
add chain=prerouting protocol=tcp dst-port=5101 action=mark-connection \ new-connection-mark=others passthrough=yes comment=“” disabled=no
add chain=prerouting connection-mark=email action=mark-routing \ new-routing-mark=emailrouting passthrough=yes comment=“” disabled=no
add chain=prerouting connection-mark=web action=mark-routing \ new-routing-mark=webrouting passthrough=yes comment=“” disabled=no
add chain=prerouting connection-mark=others action=mark-routing \ new-routing-mark=othersrouting passthrough=yes comment=“” disabled=no
  1. in the NAT (ip firewall)
add chain=srcnat out-interface=wan1 routing-mark=emailrouting
action=src-nat to-addressses=xxx.xxx.xxx.xx1
add chain=srcnat out-interface=wan2 routing-mark=webrouting
action=src-nat to-addressses=xxx.xxx.xxx.xx2
add chain=srcnat out-interface=wan3 routing-mark=othersrouting
action=src-nat to-addressses=xxx.xxx.xxx.xx3
  1. in the ROUTE (ip route) wan1 (xx1) wan2 (xx2) wan3 (xx3)
add dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.xx1 scope=255 target-scope=10
routing-mark=emailrouting comment=“” disabled=no
add dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.xx2 scope=255 target-scope=10
routing-mark=webrouting comment=“” disabled=no
add dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.xx3 scope=255 target-scope=10
routing-mark=othersrouting comment=“” disabled=no
moengoet -
At first glance your thoughts look sound - the only thing I saw amiss was you using masqurade vice src-nat. I believe that MT OS will just masqurade to the address of it’s choice - which is usually the lowest IP number on the first outgoing interface… So I would change your masq rule to src-nat to the particular IP address you want on the interface you expect to use for the different packet/connection/route markings.
Thom
good point galaxynet,
thank you.
the other point is,
if the gateway’s IP is DYNAMIC, how do we dynamically change the src-nat’s address?
moengoet -
If you do a quick search of the forum or take a look at the manual you’ll find that is a common question - it has been answered many times.
Not being a smart #$#, I just have never used that as all of my lines have static IPs - so I never stored the knowledge as to how to do that…
Thom
