Hello all!
The situation is…
I need to make 3 vpn connections, that each will have own Internet gateway to specific external IP.
For example:
Internal VPN IP after connect is 192.168.10.115. And it will have external IP 11.11.11.115
Internal VPN IP after connect is 192.168.10.116. And it will have external IP 11.11.11.116
My working example, based on 3 different gateways (and works good):
/ip firewall address-list
add address=192.168.10.0/24 list=Connected
add address=192.168.10.0/24 list=LAN
/ip firewall mangle
add chain=prerouting src-address-list=Connected dst-address-list=Connected action=accept/ip firewall nat add action=masquerade chain=srcnat out-interface=ether1-gateway src-address=192.168.10.115
/ip route add gateway=11.11.11.65 routing-mark=115
/ip firewall address-list add address=11.11.11.115 list=Connected
/ip firewall mangle add chain=prerouting src-address=11.11.11.115 action=mark-routing new-routing-mark=115
/ip firewall mangle add chain=input connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=115-ros
/ip firewall mangle add chain=forward connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=115-lan
/ip firewall mangle add chain=prerouting connection-mark=115-lan src-address-list=LAN action=mark-routing new-routing-mark=115/ip firewall nat add action=masquerade chain=srcnat out-interface=ether2-gateway src-address=192.168.10.116
/ip route add gateway=11.11.11.66 routing-mark=116
/ip firewall address-list add address=11.11.11.116 list=Connected
/ip firewall mangle add chain=prerouting src-address=192.168.10.116 action=mark-routing new-routing-mark=116
/ip firewall mangle add chain=input connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=116-ros
/ip firewall mangle add chain=forward connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=116-lan
/ip firewall mangle add chain=prerouting connection-mark=116-lan src-address-list=LAN action=mark-routing new-routing-mark=116/ip firewall nat add action=masquerade chain=srcnat out-interface=ether3-gateway src-address=192.168.10.117
/ip route add gateway=11.11.11.67 routing-mark=117
/ip firewall address-list add address=11.11.11.117 list=Connected
/ip firewall mangle add chain=prerouting src-address=192.168.10.117 action=mark-routing new-routing-mark=117
/ip firewall mangle add chain=input connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=117-ros
/ip firewall mangle add chain=forward connection-mark=no-mark in-interface=ether2-gateway action=mark-connection new-connection-mark=117-lan
/ip firewall mangle add chain=prerouting connection-mark=114-lan src-address-list=LAN action=mark-routing new-routing-mark=117
If we have 3 different gateway (11.11.11.65, 11.11.11.66, 11.11.11.67) for each external IP (11.11.11.115, 11.11.11.116, 11.11.11.117) - all working good, as i need.
BUT! The problem is… that i have only 1 gateway (11.11.11.65) for each external IP (11.11.11.115, 11.11.11.116, 11.11.11.117)…
And all 3 vpn connections get the same 1 external (first of 3) - 11.11.11.115
Is it possible to separate routes to each of IP (11.11.11.115, 11.11.11.116, 11.11.11.117) with 1 gateway (11.11.11.65) ?
Maybe i don’t now/undestand something… (
