i have a MT install on a pc.. in the last few days my sistem stop responding to ping for 3 -5 minutes ( neither from local network nor the public one ) after that it start working just fine but it stopes in about 1-10 minutes from then…and so on …and so one..
i use hotspot and the users conected to the hotspot remain conected the whole time but can do nothing .
i don’t know if dave something to do whit is but on log i can see more often this error mesage: rbuffer.cpp:52: conection reset by peare
the cpu load is 1-5% this is the normal load for my sistem
i could not disabled the public interface becouse i am not in the same location as the router is. but if you think that could be a problem whit the public network card (maybe a fizical problem), i will tri to ritch to the souter (is far away) and se what hapends if i disable public network and i’ll post the conclusions here.
