I need to do a 3 point PtP link using mikrotik A->B->C
A to B will be VERY short <1000’ and will use 5.2ghz. B->C will be
about 13 miles using 5.8 Ghz. LOS should be excellent with no
obstructions for both links.
This will start as a half-duplex link and be moved up to a full-duplex
if things work out. Also, I would love to move as much traffic as
possible 50mbps would be great 20-30 would be the minimum. This will
start out as a nstreme link and then to a nstreme2 link.
My plan was a rb532 or itx solution at point A using CM9 or equivalent
cards. Site B would need to be an ITX board using CM9 and SR5 or
equivalent cards. Site C would be a rb532 or ITX using SR5 or
equivalent cards.
First phase A & C will have 1 card each and B with have 2 cards. After
the upgrade A & C will have 2 cards and B will need 4 cards.
Questions are
Are there harden ITX systems that can handle 4 mini-pci cards with
enough horse power to push over 200mbps (50 per card). -
Will 4 cards running full power be too much wattage for the board?
Will 2 SR5 cards run OK in a RB532?
Will a RB532 be able to handle all that bandwidth in full duplex
mode? -
Solution needs to be able to handle the environment high
heat/sun/lightning.
