What i want to do is use 1 st account for my internal LAN, and other two as dst-nat some services inside my LAN. (no load balancing)
Issues:
PING is working only on the first pppoe account, other two are working (including ping) if i change my default route with distance 1 to another pppoe.
I tried to mark packets for each pppoe account and it does not work, but this looks more like a load balancing situation which i don’t want.
Can somebody help me ? I just want to have all of the 3 pppoe accounts alive on the router, only 1 will be used for internal LAN.
You should mark route the packets and then add default route with the chosen routing mark.
For example
/ip route add gateway=pppoe2 routing-mark=wan2
Use mark route in action of routing mark, I don’t remember the exact syntax for the command, but you can use dst-address your LAN Network and the port you need, or the input interface, and then in the action mark route.
In the end masquerade your LAN with an output interface list.
Ok already tried it does not work, can’t go out to internet with the bellow rules.
I can ping the outside ony from mikrotik router on both pppoe accounts.
Ping from internet to router is working.
I think there’s something wrong in mangle, with these you’re marking connections that are coming in, not those going out to pppoe2 or 3.
Can you please post a screenshot of the connection in connection tracking?
You should make a mangle with src address 192.168.88.0/24 protocol and port you natted for routing mark, so when for example 192.168.88.123:80 should go through another PPPoE it you dst-nat port 80 to 192.168.88.123
Try to use
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=pppoe2 passthrough=no src-address=192.168.88.0/24 protocol=tcp src-port=80
True, a single mangle route rule was enough for the webserver IP (no tcp / port), with a single route in routing table.
Everything remained as a basic configuration with NAT.
Thanks.
