3 second link drop problem
Hi to all
I have 3 link net box 5 with 32db kenbotong dish
bandwidth test is good enough for our work but link drop 3 second and then go up in bandwidth test.
here is image:
any one can help or say what means this?
thank you
Go take a look in the logs. it should show why the link is dropping.
Usually its something like extensive data loss or not polled for too long
thank you but no message appear in log when link drops.
any suggest?
Are you using a bridge port with RSTP enabled. This can cause some issues.
