As I’m trying to understand what can I do with 2 RB751, I want to ask you some things:
I want to deploy next scenario:
main RB751
3 VLAN.
- 1 VLAN + DHCP for LAN devices.
- 2 VLAN + DHCP for WiFi devices with 2 SSID
Then trunk these VLANs to another RB751 and then set same config but without using DHCP servers.
I’ve set this config using bridges but cannot see the way to trunk to another device. I know these are routers and should do it with a swith, but this is what I have and what I want to test.
Is that possible? What should be the best way to do it?
Regards.
