Hello guys, first sorry for my bad english! im doing this reading various guides and the wiki, still cant find anyone with this problem, or either other users use 1 lan, or 1 on 1 wan/lan distribution
I have a problem with this:
I got 3 wan connections that is should distribute 2:2:1 ratio
and i got two separate LAN and they never have to communicate with each other.
i got 1 rb750 to do the balance and distribution, and the two lan connections are managed by two rb1100ahx2 ( previous network administrator created two physical networks instead of vlans)
Thanks!
TL;DR: I want balance and failover with the 3 connections to the 2 lan.
set [ find default-name=ether1 ] comment=Alumnos
set [ find default-name=ether2 ] comment=Admin disabled=yes
set [ find default-name=ether3 ] comment="Fiber 6M" disabled=yes
set [ find default-name=ether4 ] comment="Fiber 50Mv2" disabled=yes
set [ find default-name=ether5 ] comment="Fiber 50Mv1" disabled=yes
add address=10.103.100.10 comment=6MBFiber interface=ether3 network=10.102.100.10
add address=10.103.100.20 comment=50MBFiberv2 interface=ether4 network=\
10.101.100.10
add address=10.103.1.3 comment=50MBFiberv1 interface=ether5 network=\
10.103.100.10
add address=10.0.0.250/24 comment="Salida a Alumnos" interface=ether1 \
network=10.0.0.0
add address=192.168.0.250 comment="Salida a Administracion" interface=ether2 \
network=192.168.0.250
set servers=199.85.126.20,199.85.127.20
/ip firewall address-list
add address=10.101.100.0/24 list=Conectados
add address=10.102.100.0/24 list=Conectados
add address=10.103.100.0/24 list=Conectados
add address=10.0.0.0/24 list=Conectados
add address=192.168.0.0/24 list=Conectados
add address=192.168.0.0/24 list="Lan ADMIN"
add address=10.0.0.0/24 list="Lan Alumnos"
/ip firewall mangle
add action=mark-connection chain=input in-interface=ether4 \
new-connection-mark=in_fiber50v2 passthrough=no
add action=mark-connection chain=input in-interface=ether5 \
new-connection-mark=in_fiber50v1 passthrough=no
add action=mark-connection chain=input in-interface=ether3 \
new-connection-mark=in_fiber6m passthrough=no
add action=mark-routing chain=output connection-mark=in_fiber50v1 \
new-routing-mark=Out_Fiber50v1 passthrough=no
add action=mark-routing chain=output connection-mark=in_fiber50v2 \
new-routing-mark=Out_Fiber50v2 passthrough=no
add action=mark-routing chain=output connection-mark=in_fiber6m \
new-routing-mark=Out_Fiber6 passthrough=no
add action=accept chain=prerouting dst-address=10.102.100.0/24 in-interface=\
ether2
add action=accept chain=prerouting dst-address=10.101.100.0/24 in-interface=\
ether2
add action=accept chain=prerouting dst-address=10.103.100.0/24 in-interface=\
ether2
add action=mark-connection chain=prerouting dst-address-type=!local \
in-interface=ether2 new-connection-mark=in_fiber50v2 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:5/0
per-connection-classifier=both-addresses-and-ports:5/1
in-interface=ether2 new-connection-mark=in_fiber50v1 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:5/2
per-connection-classifier=both-addresses-and-ports:5/3
in-interface=ether2 new-connection-mark=in_fiber6m passthrough=yes \
per-connection-classifier=both-addresses-and-ports:5/4
add action=mark-routing chain=prerouting connection-mark=in_fiber50v1 \
in-interface=ether2 new-routing-mark=Out_Fiber50v1
add action=mark-routing chain=prerouting connection-mark=in_fiber50v2 \
in-interface=ether2 new-routing-mark=Out_Fiber50v2
add action=mark-routing chain=prerouting connection-mark=in_fiber6m \
in-interface=ether2 new-routing-mark=Out_Fiber6
add action=masquerade chain=srcnat out-interface=ether3
add action=masquerade chain=srcnat out-interface=ether4
add action=masquerade chain=srcnat out-interface=ether5
add check-gateway=ping distance=1 gateway=10.103.100.1 routing-mark=Out_Fiber6
add check-gateway=ping distance=1 gateway=10.103.100.3 routing-mark=\
Out_Fiber50v1
add check-gateway=ping distance=1 gateway=10.103.100.2 routing-mark=\
Out_Fiber50v2
