3 WAN load balancing and failover.
Hello Everyone.
I am using RB2011UiAS-2HnD
I removed default configuration and connected 3 WAN from 3 different ISP, 1 LAN.
First WAN on first port/ POE using PPPoE connection.
Second WAN on 2nd port using DHCP client.
Third WAN on 3rd port using DHCP client.
LAN is connected on Port 4 using DHCP server.
How can I combining all these 3 connection to get higher speed and redundancy.
I also have OpenVPN server with dedicated IP hosted on different country.
Is this possible to add this VPN in mikrotik router to gain maximum speed and secure uninterrupted session from above 3 line combination.
Thanks in advance.
