I have 3 wan
I did load balancing with failover PCC
What I need to know:
if wan1 bandwidth is fully used how to move new packets to wan2 or wan3 “The empty Bandwidth”
In my case if wan1 “8mb” is fully used & another user wants to download its too slow & dont move to wan2 or wan3,
Help Please,
Regards,
pcc is per tcp/ip connection basis load balancing and is not perfect, pcc distributes tcp/ip connections across the wan connections.
the load balancing is done at the start of the tcp/ip connection, at that moment there is no way to know how many traffic that connection will transfer
your problem is that if a big tcp/ip connection and a little tcp/ip connection share a wan connection, then the big connection starve the little connection
i think you must queue traffic to distribute or prioritize the available bandwidth between the tcp/ip connections or clients using a specific wan connection
