3.x on 411 authentication problem...
I have just tested a client configuration on the rb411 board.
It uses freeradius and EAP-TLS to authenticate.
It has worked on 133’s with 2.9.x without any problem.
411 authenticates successfully. Then you can see it momentarily registering but then after a few seconds it attempts to authenticate again, and continues to do so.
Can anyone assist ?
make the support output file right after that and send it to support@mikrotik.com with the description of the problem.
Did that earlier today. Thanks.
