Hi
Up till now I have always setup point to point links using SXTs at both ends and this works great.
Recently I began offering Internet access to companies that are within viewable distance of my office (max 5kms).
So I thought that I could setup a sector antenna at my base, say a RF Elements 5GHz 17dbi sector Class (2x2 H+V),
hooked up to a Netbase 5 (RB912UAG), and equip my customer sites with SXT 5 Lite.
I’m testing this setup in my office, which is what I usually do when setting SXT<->SXT links, and discover that I can’t manage to obtain a 300/300 Mbps (TX/RX) link between the two devices
I have used the same parameters I use to link two SXT devices together: [bridge<=>stationbridge], 5GHz-Only-N, nv2, both chains active
When I look at the wireless registration tab the link remains at 6.5/6.5 Mbps (TX/RX)
If I run a bandwidth test between the two (TCP, send & receive) I reach 77/60 Mbps (TX/RX) - total average
So my question is, should I stick to SXT-SXT setups and forget sector antennas i.e. what I’m trying to do can’t be done
Or may this is just a situation where you can’t, in such close proximity, obtain the desired result
I tried to reduce the transmit power on both devices but this brought no marked improvement
yann
