300 Mbps throughput using RB800 and WI antennas
Hello Guys,
Looking for efficient point to point link i found the article on the website of one antennas manufacturer.
Can anyone confirm this unbelievable story?
This is the link:
http://www.wireless-instruments.com/en/13/can-you-imagine-link-over-300-mbps-with-routerboard-and-mimo-2x2-antenna-.html
What do you think about it?
what is so unbelievable? If your local regulatory domain allows use of wider channels there are no issues creating link.
Since it is in a field, and there are probably no 5 GHz interferers, so your channel will be “clean”, and will have only free space loss.
on 11n it can go more than 200Mbps ???
do i need to use custom channel width???
and it’s the custom channel width support nv2 now???
Yes!!! :smiley:
