i need your help. I have startet with a hAp AC lite and it works fine. Now i go with 3011RM and i want to use 2 AC’s as CapsMan controlled Wireless AP’s.
I go out on 3011 ETH10 to AC on ETH1 (PoE In).
I want to use Switch Ports 2 to 5 on the AC device for vlan11 which is working on a bridge on the 3011.
Wireless config should be over CapsMan but there will be 2 wireless networks (one matched to vlan11 and one separate as a guest wlan).
My questions:
-How should i configure ETH10 on 3011 ? Should i put here the management network and vlan11 on it?
-What is needed for the Wireless config on ETH10 port?
-How should i configure ETH1 on the AC device? Which vlan’s and which for wireless?
-Is there a need to configure the firewall also on AC device or only on 3011?
-Now i have no internet on AC… which route or settings are needed so that AC get’s internet?
Thanks a lot.
Regards,
Ben
