How do I know which physical port is which? On the GUI I dont see anything that says what a physical port is labeled. When I set this up I left the names with like ether7, ether5 etc so I know what physical port I am referring to. If I changed the names of the ports then I think I would be lost. I am guessing there is something that defines the ports to the physical port?
mark@MikroTik] > inter
[mark@MikroTik] /interface> print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 RS Alarm ether7 ether 1500 1598 8156 CC:2D:E0:E3:55:6D
1 RS Den Office Switch ether8 ether 1500 1598 8156 CC:2D:E0:E3:55:6E
2 S Garage Barn Switch ether5 ether 1500 1598 8156 CC:2D:E0:E3:55:6A
3 R Internet ether1 ether 1500 1598 8156 CC:2D:E0:E3:55:66
4 RS LR LG TV ether9 ether 1500 1598 8156 CC:2D:E0:E3:55:6F
5 RS LR Sonos ether6-master ether 1500 1598 8156 CC:2D:E0:E3:55:6C
6 RS Upstair Master Switch ether10 ether 1500 1598 8156 CC:2D:E0:E3:55:70
7 RS ether2-master ether 1500 1598 8156 CC:2D:E0:E3:55:67
8 RS ether3 ether 1500 1598 8156 CC:2D:E0:E3:55:68
9 S ether4 ether 1500 1598 8156 CC:2D:E0:E3:55:69
10 S sfp1 ether 1500 1600 8158 CC:2D:E0:E3:55:6B
11 R ;;; defconf
bridge bridge 1500 1598 CC:2D:E0:E3:55:67
Sob
August 15, 2019, 4:11pm
2
Use “/interface print detail” and look for default-name.
I tried that and it doesnt show the info either. But I did find the port number by doing this below. I am assuming this is the only place to find the port number.
[mark@MikroTik] /interface bridge port> print stats
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
0 I H ;;; defconf
interface=ether2-master bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no
pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query
fast-leave=no status=in-bridge [b]port-number=1[/b] role=disabled-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=no forwarding=no
hw-offload=yes hw-offload-group=switch1
1 H ;;; defconf
interface=LR Sonos ether6-master bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no
multicast-router=temporary-query fast-leave=no status=in-bridge [b]port-number=6 [/b]role=designated-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=no
learning=yes forwarding=yes hw-offload=yes hw-offload-group=switch2
2 I ;;; defconf
interface=sfp1 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=no auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
status=in-bridge port-number=5 role=disabled-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=no forwarding=no hw-offload=no
3 H interface=ether3 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
status=in-bridge port-number=2 role=designated-port edge-port=yes edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=yes forwarding=yes hw-offload=yes
4 I H interface=ether4 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
status=in-bridge port-number=3 role=disabled-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=no forwarding=no hw-offload=yes
5 I H interface=Garage Barn Switch ether5 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
multicast-router=temporary-query fast-leave=no status=in-bridge port-number=4 role=disabled-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes
learning=no forwarding=no hw-offload=yes hw-offload-group=switch1
6 H interface=Alarm ether7 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1
status=in-bridge port-number=7 role=designated-port edge-port=yes edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=yes forwarding=yes hw-offload=yes
7 H interface=Den Office Switch ether8 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
multicast-router=temporary-query fast-leave=no status=in-bridge port-number=8 role=designated-port edge-port=yes edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes
8 H interface=LR LG TV ether9 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no
fast-leave=no status=in-bridge port-number=9 role=designated-port edge-port=yes edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=yes learning=yes forwarding=yes
9 H interface=Upstair Master Switch ether10 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
multicast-router=temporary-query fast-leave=no status=in-bridge port-number=10 role=root-port edge-port=no edge-port-discovery=yes point-to-point-port=yes external-fdb-status=no sending-rstp=no
learning=yes forwarding=yes root-path-cost=10 designated-bridge=0x8000.A0:40:A0:64:51:29 designated-cost=0 designated-port-number=2 hw-offload=yes hw-offload-group=switch2
[mark@MikroTik] /interface> print detail
0 RS name="Alarm ether7" default-name="ether7" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6D last-link-up-time=aug/15/2019 09:07:30 link-downs=0
1 RS name="Den Office Switch ether8" default-name="ether8" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6E last-link-up-time=aug/15/2019 09:07:47 link-downs=0
2 S name="Garage Barn Switch ether5" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6A link-downs=0
3 R name="Internet ether1" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:66 last-link-up-time=aug/15/2019 09:07:32 link-downs=0
4 RS name="LR LG TV ether9" default-name="ether9" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6F last-link-up-time=aug/15/2019 09:07:30 link-downs=0
5 RS name="LR Sonos ether6-master" default-name="ether6" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6C last-link-up-time=aug/15/2019 09:07:30 link-downs=0
6 RS name="Upstair Master Switch ether10" default-name="ether10" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:70 last-link-up-time=aug/15/2019 09:07:31 link-downs=0
7 S name="ether2-master" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:67 link-downs=0
8 RS name="ether3" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:68 last-link-up-time=aug/15/2019 09:07:32 link-downs=0
9 S name="ether4" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:69 link-downs=0
10 S name="sfp1" default-name="sfp1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1600 max-l2mtu=8158 mac-address=CC:2D:E0:E3:55:6B link-downs=0
11 R ;;; defconf
name="bridge" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1598 mac-address=CC:2D:E0:E3:55:67 last-link-up-time=aug/15/2019 09:07:28 link-downs=0
Sob
August 15, 2019, 9:00pm
4
Look closely at what you posted.
0 RS name=“Alarm ether7” default-name=“ether7” type=“ether” mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6D last-link-up-time=aug/15/2019 09:07:30 link-downs=0
1 RS name=“Den Office Switch ether8” default-name=“ether8” type=“ether” mtu=1500 actual-mtu=1500 l2mtu=1598 max-l2mtu=8156 mac-address=CC:2D:E0:E3:55:6E last-link-up-time=aug/15/2019 09:07:47 link-downs=0
Yes its also has the PORT_NUMBER both I assume are not able to modify.
Thank you for the help!
