Hello Everyone,
I am trying to find out a model in Mikrotik that i can hit at 30 mile range. Bandwidth is not a concern for me i don’t need more than 5Mb. Can you guys suggest anything?
Hello Everyone,
How tall is your tower?
Yeah, I’d check line of sight first.
Then have a look here https://i.mt.lv/cdn/product_files/antenas-160404123306_160406.pdf
Your realistic choices are the following families. LHG, QRT or Dynadish
You need to consider the Tx power, antenna gain, Rx sensitivity and your local allowed laws regarding Tx power.
You will need all the gain you can get… I’d use LDF with 1m offset dishes. it’s cheaper solution than QRT or Dynadishes and you get much more gain and regulations-breaking power you may or may not care about…
This guide to PtP product selection may assist -
https://mikrotik.com/products/ptp
Length of tower at Point A is 100Ft and and Point B is 250 Ft and we have a line sight also there is an existing link from a different vendor which is Motorola radios. Distance from A–>B is 50km i need to hit and as i said i don’t need more than 5Mb bandwidth to use.
If it is 50Km i need much gain as possible. Any suggestions please.
