Hi, I am a newbie and trying to get a 3560 cisco switch connected to a rb2011-rm router. I have created a couple of vlans on the switch, made gig0/6 the trunk connected to ether5 on the MT-rm2011. I have removed ether5 as a slave on the MT and created a vlan trunk to carry both vlans. My PC cannot get an IP on both the vlans when connected to the cisco switch. I created a bridge (bridge-trunk) and created the vlan interfaces for 100 and 200. Please help on what is wrong on this setup. Attached both configs from the MT and the cisco switch. Thank you for your help.
cisco config:
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/3
interface GigabitEthernet0/4
switchport access vlan 200
interface GigabitEthernet0/5
interface GigabitEthernet0/6
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 100,200
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface Vlan1
ip address 192.168.10.200 255.255.255.0
interface Vlan100
no ip address
interface Vlan200
no ip address
ip default-gateway 192.168.10.1
MT config:
[admin@MikroTik - RM2011] > /export compact
jun/25/2016 06:48:43 by RouterOS 6.35.4
software id = E5ED-QXG8
add admin-mac=4C:5E:0C:77:B6:25 auto-mac=no comment=defconf name=bridge
add name=bridge-trunk
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether6 ] name=ether6-master
set [ find default-name=ether7 ] master-port=ether6-master
set [ find default-name=ether8 ] master-port=ether6-master
set [ find default-name=ether9 ] master-port=ether6-master
set [ find default-name=ether10 ] master-port=ether6-master
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
/interface vlan
add interface=bridge-trunk name=vlan-100 vlan-id=100
add interface=bridge-trunk name=vlan-200 vlan-id=200
add name=dhcp ranges=192.168.10.20-192.168.10.254
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add name=dhcp_pool2 ranges=192.168.200.2-192.168.200.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=vlan-100 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface=vlan-200 name=dhcp2
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge-trunk interface=ether5
add address=192.168.10.1/24 comment=defconf interface=ether2-master network=192.168.10.0
add address=192.168.100.1/24 interface=vlan-100 network=192.168.100.0
add address=192.168.200.1/24 interface=vlan-200 network=192.168.200.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.10.0/24 comment=defconf gateway=192.168.10.1
add address=192.168.100.0/24 gateway=192.168.100.1
add address=192.168.200.0/24 gateway=192.168.200.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.1 name=router
add chain=input comment="defconf: accept ICMP" protocol=icmp
add chain=input comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=ether1
add chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1
/system clock
set time-zone-name=America/Chicago
/system identity
set name="MikroTik - RM2011"
/tool mac-server
/tool mac-server mac-winbox
