386 Motherboard
Hi Guys,
Has anybody tried running a PCIe card on a mini pci sor PCIe socket that is working well?
We tried a few mother boards:
Asus,
Foxcon
Had no success
Yes, it works as long as you use supported hardware:
http://wiki.mikrotik.com/wiki/Supported_Hardware
Do you know how old this list is?
Some of these boards are obsolete.
The new generation Asrocks etc have PCIe “3”
The old boards no longer available.
It is not the PCI I am trying to get to work but the PCIe .
Some of the boards in the list does not even have PCIe.
Thanks for you response.
Some of the boards on the list DO have PCIe. Mikrotik works with PCIe as long as the chipset is supported.
Unfortunately, the only sure way to know, if it isn’t on the list, is to get it then try it then mark it on the list yourself one way or the other. If it doesn’t work, you can email mikrotik and ask if they can add support for that particular chip or not.
Its also possible to check, what pcie drivers are supped from the mikrotik list, and check if anny of the new hardware use the same Linux kernel driver for the hardware.
Thanks for the info. It is difficult to be dumb.
I will ask Mtik for a list of supported PCIe drivers.
We don’t have such lists. The only way is to test.
Thanks,
Do you guys have a list of which PCIe chip sets you support in you kernel?
Kernel is one thing, and actually tested is another. We don’t want to promise anything, and then find out that it’s not working.
On what boards did you test then new RB14?
