Hi i need to set both wireless interface of my home routerboard(my test box) to disable-running-check=yes because in the Ports table of the bridge, boths are Invalid because was detected like disabled ports…
Now all work great ![]()
Regards!
Alessio
Hm, are your clients connected to these wireless interfaces at this time ?
“I” should be shown unless AP/client does not establish connection with remote device.
Yes, a wlan card is for connect to my ISP and the other is an internal AP to connect to the wifi cellular, and boths was connected and in the wireless table boths are "R"unning
Alessio,
could you please specify ,
- ‘I’ status was shown on bridge port even clients were connected to the particular interface
or - ‘I’ status was shown on bridge port, when the particular interface does not have any connected client.
Second situation is normal behavior, it works as it designed.
i know about this status, because this i do the change…
when i see in the first bootup clients are connected but the port status are I
but after a reboot i try again and the problem was solved…
sorry for not try this to reboot before post this problem…
now work great with disable-running-check=yes or no ![]()
Thanks and regards!
Alessio
Generate support output file, if you will notice the same issue again.
Send it to support@mikrotik.com
