3c905C-TX/TX-M not works auto negotiation, full duplex & link status:
[xxx@19KV] interface ethernet> moni 0
status: no-link
auto-negotiation: disabled
rate: 10Mbps
full-duplex: no
default-cable-setting: standard
in winbox status “nolink, rate 10mb, no full duplex”
it is tested on many deskside and network card
with Intel pro100, via, rtl & other lan card its ok
this card does not work (for me at least) connected to an AP or connected to a LAN. I have tried to use all the combination possible configurations to no avail.
I’ve got the same problem.
In 2.8.x it works 100mbit and full duplex and with auto negotiation,
but in 2.9.x can only run 10mbit and half fuplex without auto negotiation.
I send both sup.rif (from 2.8 and 2.9) to Mikrotik and nobody aswered.
