3com wireless controller, how to fix the problem
hi, i’ve got a problem using routerboard at my place.
we’re using 3com wireless controller for backbone. client can be connect to internet if using 3com ap2750 (thin ap).
the problem is, when i connect directly from controller via switch to ap2750, the link is ok. but when i connect from controller via switch and routerboard to ap2750, it give a problem. i can get the ip addres from controller but cannot browse.
i hav passthrough the firewall.
hopefully someone outside know about this. thanx
what configuration your routerboard have? what configuration your PC have? what addresses are used
i don’t use computer because this is a wireless link between controller and thin ap (ap2750). i just make a same ssid and channel, enabled bridge and port for ether1 and wlan1,mode is ap bridge and station wds for another end,and i make passthrough for nat firewall.
