From someone or Mikrotik itself, is it possible to receive 3D print file for some antennas like LHG5?
I am curious to know why you want the 3D-Print Files ?
Did something break on your device ?
Quick analysis LHG5 for 3D-Printing
Part 1: Main Dish
- Can only be printed on a 3D-Printer with a Bed of min 400x400 cm (most printers are 230x230cm)
- Dish attachment point needs to be modified for 3D-Printing or moved to a seperate component.
Part 2: Primary Antenna-Arm (with Router)
- Difficult to print without any modification (needs a lot a support-Material)
- May have to separated in two components (Arms and receiver-hub)
Part 3: Secondary Antenna-Arms
- Easy to print without any major modification
I have same LHG WLan modules from damaged LHG xl Antennas. I want use the modules. Can I got the 3D printing Files from mAnt 5o case, the LHG Modules can I place in I think.
So long…
- You can sell LHG modules
- You can use other parabolic antennas for these modules.
- You will not be able to print the LHG antenna on your printer.
You can only print if your printer can print the metal base of the antenna.
