3G/4G router-AP assembling
I will like to assemble this parts together. This will be hotspot router for remote location. i was wandering if this parts are compatible and if the Routerboard RB411UAHR comes with mikrotik OS:
RB411UAHR
R52Hn
Sierra Wireless MC7710/MC7700 card
CA411-711
Any reason to go for this over the WAP-LTE Kit ?
maybe for three common reasons:
  1. device overheating problem (passive cooler falls off)
  2. sometimes missing lte interface
  3. need for constant reboot to reconnect (automatically with scripts)
the device is premature, I believe that this shortage of devices on the stock is the result of hardware modifications in progress and release of new version.
p.s. I love wap LTE and I hope for positive outcome.
The reason is the need for external LTE and wifi antennas. We are planing to place it inside buses.
If you are going to produce a few of these it would also be good to look at another LTE module as the mentioned ones both are EOL…
There’s a bunch of alternatives out there.
