3G bonding solution
Hi!
I am trying to find a solution for my following scenario.
I will be using a server in a moving truck that needs to receive video feeds.
Since there will be no Sattelite connection available we will need to use the multiple bonded 3G modem interfaces.
In our streaming devices we can define only one public server IP/hostname that the stream will arrive to.
I’m thinking of a solution that will bond all available 3G modems (we will use min 4) and make a PPP or VPN connection that will allow us to keep the IP constant, or a dynamic DNS solution.
Any ideas ? DO you have such product or at least one that would fit to my scenario ?
Thanks,
Liviu
Hi guys !
Nobody aware about any solution ?
Bump!
I think a Netgear Hotspost should get your project running, let’s say the AirCard 760S should get you 5 Wi-Fi enabled devices connected at the same time, or you can get a 4G LTE modem and connect it to a wireless router like the Tp-Link 4gsource.net/3g-4g-routers/wireless-home-routers/4g-lte/tp-link-tl-mr3420.html
Please share few more detailes about your project, what is the estimated distance between the Wi-Fi devices?
