3G Modem works under X86@3.24, not supports in RB433UAH@3.24
Hi, guys!
I connected a Huawei EC1260 3G Modem to a X86@3.24, it works correct.
[admin@MikroTik] > /syst reso usb prin
DEVICE VENDOR NAME SPEED
0 5:1 UHCI Host Controller 12 Mbps
1 4:1 UHCI Host Controller 12 Mbps
2 3:1 UHCI Host Controller 12 Mbps
3 2:1 UHCI Host Controller 12 Mbps
4 1:1 EHCI Host Controller 480 Mbps
5 3:3 HUA\FFWEI TECHNOLOGIES HUAWEI Mobile 12 Mbps
[admin@MikroTik] > port prin
Flags: I - inactive
NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 Serial Console 9600
1 usb2 3 115200
[admin@MikroTik] > syste pac prin
Flags: X - disabled
NAME VERSION SCHEDULED
0 system 3.24
1 wireless-test 3.24
2 X wireless 3.24
3 user-manager 3.24
4 ups 3.24
5 stpbridge-legacy 3.24
6 security 3.24
7 routing 3.24
8 ntp 3.24
9 multicast 3.24
10 X routing-test 3.24
But in the RB433UAH@3.24, I can not find a new port. It seems the RB433UAH don't recognise the 3G modem.
Can anybody tell me how to fix it?
[admin@mobile2] > /syste reso usb print
0 2:1 RB400 EHCI 480 Mbps
1 1:1 RB400 OHCI 12 Mbps
2 1:2 HUA\FFWEI TECHNOLOGIES HUAWEI Mobile 12 Mbps
[admin@mobile2] > /port print
Flags: I - inactive
0 serial0 1 Serial Console auto
[admin@mobile2] > syst pack prin
Flags: X - disabled
0 gps 3.24
1 ntp 3.24
2 system 3.24
3 calea 3.24
4 wireless 3.24
5 routeros-mipsbe 3.24
6 user-manager 3.24
7 routerboard 3.24
8 ppp 3.24
9 dhcp 3.24
10 hotspot 3.24
11 routing 3.24
12 advanced-tools 3.24
13 multicast 3.24
14 security 3.24
15 ups 3.24
I reply this topics by myself. The drivers is different between RB and X86 OS.
Try 3.27
Thank you!
I have tried it in 3.27, and 3.27 is not support the 3G modem. In China mainland, we can use WCDMA, CDMA2000 and TD-CDMA. I think MK supports WCDMA modem well, supports some CDMA2000 modem under X86, and don’t support TD-CDMA modem.
if some modem is not supported, make a supout.rif file in the latest RouterOS version, while the modem is plugged in, and send this file to mikrotik support. We will look at it, and will try to make this modem working.
