Ok, I have search mikrotik forum and also google. I am using 3g with USB Huawei modem on roterOS. Is it possible to read signal level even if I am using ppp over 3g modem? The problem is that I can’t believe that such option is not implemented. The routers os 20$ can do that but Router OS cannot. Or I can’t realize how to do that.
int ppp-client info PPP
working only when usb modem is not used for data
Mine runs this way
[engineer@centre] /interface ppp-client> info
number: ppp-out1
modem-status: call in progress
pin-status: no password required
functionality: full
manufacturer: huawei
model: E173
revision: 11.126.16.05.200
serial-number: 860015019027074
current-operator: 62160 (cellid unknown)
access-technology: GSM compact
signal-strengh: -61 dBm
frame-error-rate: n/a
But I have monitored it, yet it is still in GSM compact, how do i make the access technology change to 3G, because 3G is in that area.
The picture is attached in it.
