anyone having a problem with unsupported USB 3G modems? send supout.rif or instructions how to access your router to support [at] mikrotik.com and we will add support.
Hello Normis
ROS tested at 3.23
My Huawei e226 runs on x86 and rb/433uah
My ZTE mf626 runs on x86 and not rb/433uah deted stores
give support usb printer sharing
Thank you
IDC
I will drop info on the sprint 598U on Mon AM …
Runs fine…
Will be leaving for Interop.. so may not make it..
Need to figure out “channels” also detection on storage devices seems schetchy..
Device has:
3G
GPS
microSD
FLASH (embedded driver “cd” image)
would be COOL if we could figure out how to use the install flash to run ROS from it…
In v3.23 and RB433UAH only work 3g USB devices? not work miniPCI-Express devices?
Arch x86 it work with miniPCI-Express devices but not in MIPSBE devices then I can’t use RB433AH with miniPCI to miniPCI-Express.
Thanks Mikrotik
