kehinde
September 6, 2011, 6:39pm
1
l install mikrotik on pc without mikrotik card and l want to use 3g usb modem for internet connection and also use the as a hotspot with a linksys router. can anyone help.
kurei
September 7, 2011, 5:28am
2
You can follow this step.
Make sure your 3G modem supported by mikrotik. For supported hardware, read this article : http://wiki.mikrotik.com/wiki/Supported_Hardware
Dial 3G modem using PPP-Client, for example read this article : http://wiki.mikrotik.com/wiki/Huawei_EVDO or this article : http://wiki.mikrotik.com/wiki/Option_Globetrotter_HSDPA_USB_Modem
When the router is already connected to the internet . Setup your Hotspot : http://wiki.mikrotik.com/wiki/Hotspot_server_setup
If you want to use external Access Point, you have to set your external Access point as bridge.
