Hi, I have wireless link build on Intel DN2800MT,1GB ram and compex wle300nx 6a as wireless card, but I am unable to get higher wireless speeds then 300/300 Mb/s
I have the same problem. I have link 500 metres out of 3x3 antennas and cards
WLE350N5-23 7B.
The signals are acceptable in all chains.
Current-tx-powers shows maximum msc-7, it responds to link rate 300/300Mbps.
Please, have you any idea, what is the problem?
If you look at the CCQ%'s than the two best are given and a poor overall. So you should take a closer look at the CCQ’s of each individual chain. Maybe one of the chains is performing poor.
Than, if you identified a poor chain, look at its cable connections/connectors, its polorization, the environment (could it be just that polorization is beeing reflected by a metal roof?) etc.
Also try some other frequencies to see if there is no inteference.
For instance, if there is interference it will probably effect most only one chain. The one with the same polorization as the interfering signal…
ROS general status figures only produce the best found on the 3 chains. Hence good ‘top’ ccq, good signal, low noise etc. But it might well be one of the chains is doing very poor.
Why is the ‘general’ info basically telling the link is ok? Well, you can make a 300Mb conn. rate. Which can be considered ‘good’. But we know a 3 chain link can do better. ROS don’t. So dig a bit deeper and probably find the culprit.
And let us know off course! I´m also only talking out of ‘common sense’ and a bit of experience…
It is standard antenna with emitters moved 120*- Vertikal 0*,120*,240*.
The question is, how should be polarization plugged in the rard.
I have it now that chain 0 is 0*, chain 1 is 120* and chain 2 is 240*
The problem with 3 chains is that 3 polarizations have very low separation compared to 2 polarizations.
If I remember right it is only like 3to6 db compared to 12db. So in a clear LOS this might be not enough.
I see none of the 11n based gear vendors offering a 3 chain solution. So it most likely do not work very
well at all.
But to be honest I think the availability of 3 (or 4) chain antenna’s is merely a “chicken or the egg” issue. Most vendors wont make them untill there is demand for them. But demand won’t grow a lot if there are hardly antennas on the market.
Some main stream antenna makers only recently are bringing 2 chain antenna’s out…
One other solution I personally am thinking of is to use a good shielded (metal dish) dua chain antenna (H+V- pol) and to fit separately a single chain directional (also good shielded).
By fitting them with some small separation you create a high cross chain difference where from distant seen this setup still funcions as one triple chain antenna. This third antenna can than be setup with a 45 or 135 angle. (Make sure on the other end the angle is the same, not opposite! )
My only quiery I have in such setup is the length of the cables/pigtails between actual radio and the antenna(s). Should they be exactly the same, or would a difference in length (= time) make some difference to the good or bad?
