3x3 MiMo PtP Antenna Options
I have been wanting to do 3x3 MiMo for some of our backhauls for quite some time, but have yet to come across a proper antenna for this. Everything I find seems to put the antennas in the same polarizations. I see no reason that 3x3 can’t be accomplished through a parabolic dish, other than having to deal with people being confused on opposite polarizations in order to successfully accomplish this. Example: Chain 0 V-Pol, Chain 1-H/V-Pol, Chain 2-V/H-Pol, then swapping chains 1 and 2 on the opposite end. Seems like it could work perfect in theory.
Has anyone found anything for 3x3 MiMo with one antenna, in 3 different poles?
Isn’t this topic already discussed on this forum elsewhere? You should read that discussion and join if you have additional questions or information to it rather than create the same topic again.
Whats with 3 + 3 + 3 same reply, is it some hidden code :laughing: :laughing: :laughing:
This is how tapatalk handles forum outage…
Or forum did it itself.
I have searched the forums. I have found plenty of topics about 3x3 mimo, but nothing regarding antennas with 3 unique polarizations in triple chain. Also I have not found any discussion of parabolic dishes with triple chain.
Did some more searching, found a couple of antennas with unique polarizations. Still haven’t found any dishes, and that is really what’s needed. We currently use ARC Wireless ARC-DA5830SD1ARC eXsite 30dBi DP 4.94-5875GHz Dish for our long range PtPs. I would really like to find an equivalent that supports Triple Chain. Doesn’t have to be a Dish, but I need comparable signal strength to make it relevant.
Did you ever find a high gain dish? I am looking as well…
