4.13 voltage bug?
i have rb433ah and update for 4.13 version.
I have 18v power supply, but system/healt
fan-mode: auto
use-fan: main
active-fan:
voltage: 28V ???
only show 28v
My RB433AH + 12V PSU also shows 28V.
Regards, Grzegorz.
On my RB show tha same. :frowning:
Tried 3 X 433AH with 24v supply they read ok but voltage missing on the CPE’s ?
What hardware supports voltage readouts? I guess RB532A doesn’t?
only some Rb433AH show this problem. One customer left his router in our grace already and we are looking into the problem.
@janisk
I can confirm this also effects RB411 and RB711 but all of my RB433ah show voltage correctly when using winbox but I have lost “display voltage” on dude 4.0 beta2
voltage should be displayed correctly in 5.0rc4 and when next v4 is released it will be corrected there too.
affected boards was RB400 series, RB700 series that was fed with 14V or less.
My Rb433ah’s have 24volt supply’s and the RB411 or RB711 have 18 or 24 Volt supply, none was less than 14v?
