4.14 -> 5.6 Upgrade Issues
I have had a 450g for about two months and recently upgraded it to 5.6 from 4.14 (what it came with) and subsequently 5.7.
After the upgrade, I am getting some strange behaviour. It drops outgoing connections (preserving incoming connections) for a second or so, before allowing them again.
I am thinking it keeps removing the outgoing route and then adding it back in, but I am very uneducated when it comes to Mikrotik products. I have checked the logs and everything claims to be working fine.
Two interesting things: -EDIT-
  1. One person plays games [Team Fortress 2]. They will see other people move, even during the connectivity issues, while they cannot. (sending vs receiving?)
  2. Pinging will be completely fine and then respond from the gateway interface that the destination is unreachable. This will be followed by a 1000ms (+/-) and then normal operation
[admin@HoboTik] > ip dhcp-client print
 #   INTERFACE                         USE ADD STATUS        ADDRESS
 0   ;;; default configuration
     ether1-gateway                        yes bound         [WAN]/20
[admin@HoboTik] > ip dhcp-relay print
 #   NAME               INTERFACE               DHCP-SERVER     LOCAL-ADDRESS
[admin@HoboTik] > ip dhcp-server print
 #   NAME     INTERFACE     RELAY           ADDRESS-POOL     LEASE-TIME ADD-ARP
 0   dhcp1    bridge                        dhcp_pool1       3d
[admin@HoboTik] > ip dhcp-server lease print
Flags: X - disabled, R - radius, D - dynamic, B - blocked
 #   ADDRESS                  MAC-ADDRESS       HOS... SERVER    RAT... STATUS
 0   10.10.0.110              00:0A:CD:1B:71:F7 sma... dhcp1            bound
 1 D 10.10.0.149              0C:EE:E6:B1:8F:2B hob... dhcp1            bound
 2   10.10.0.105              00:1F:BC:02:66:4A Sma... dhcp1            bound
 3   10.10.0.111              00:02:B3:A9:E4:07 Sma... dhcp1            bound
 4 D 10.10.0.104              00:21:5D:5A:37:40 Jam... dhcp1            bound
 5 D 10.10.0.103              00:26:22:62:96:ED hob... dhcp1            bound
[admin@HoboTik] > ip dhcp-server option print
 # NAME                                CODE VALUE
[admin@HoboTik] > ip dhcp-server config print
  store-leases-disk: 5m
[admin@HoboTik] > ip dhcp-server network print
 # ADDRESS            GATEWAY         DNS-SERVER      WINS-SERVER     DOMAIN
   10.10.0.0/23       10.10.0.1       10.10.0.1
EDIT: By disabling/renabling DHCP, it fixed the cpu pegging issues. But it is still dropping outbound connections.
Thank you!!
There have been several posts regarding DHCP and 100% cpu. I hope that gets fixed soon!
I fixed the 100% CPU DHCP, due to a misconfiguration error: I have two /24 networks, my local and VPN networks. The DHCP server was attempting to hand out ip addresses on both, but the VPN server does the other /24, creating the cpu pegging issue.
However, my issue of outbound connections dropping still persists. It seems to me that it is dropping a route, although the routing table never changes, nothing shows up in the log, and no interfaces go down.
Here is my full config
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes \
    disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 \
    name=bridge priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526 \
    mac-address=00:0C:42:BD:5E:9F mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:BD:5E:A0 \
    master-port=none mtu=1500 name=ether2-local speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:BD:5E:A1 \
    master-port=none mtu=1500 name=ether3-local speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:BD:5E:A2 \
    master-port=none mtu=1500 name=ether4-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited \
    disabled=no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:BD:5E:A3 \
    master-port=none mtu=1500 name=ether5-local speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1 \
    switch-all-ports=no
add name=default-dhcp ranges=10.10.0.100-10.10.0.199
add name=dhcp_pool1 ranges=10.10.0.100-10.10.0.199
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=\
    static disabled=no interface=bridge lease-time=3d name=dhcp1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \
    stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=\
    default use-encryption=default use-mpls=default use-vj-compression=\
    default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=\
    default use-compression=default use-encryption=yes use-mpls=default \
    use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 \
    sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \
    red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=\
    5
set multi-queue-ethernet-default kind=mq-pfifo mq-pfifo-limit=50 name=\
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
    ignore-as-path-len=no name=default out-filter="" redistribute-connected=\
    no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in \
    metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
    auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\
    default
/snmp
set contact="" enabled=no engine-id="" location="" trap-target=0.0.0.0 \
    trap-version=1
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
    disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 \
    src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=\
    remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \
    boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \
    enter-setup-on=any-key force-backup-booter=no silent-boot=no
add bridge=bridge disabled=no edge=auto external-fdb=auto horizon=none \
    interface=ether2-local path-cost=10 point-to-point=auto priority=0x80
    interface=ether3-local path-cost=10 point-to-point=auto priority=0x80
    interface=ether4-local path-cost=10 point-to-point=auto priority=0x80
    interface=ether5-local path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.10.0.1/23 disabled=no interface=bridge network=10.10.0.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" \
    default-route-distance=1 disabled=no interface=ether1-gateway
/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address=10.10.0.110 client-id=1:0:a:cd:1b:71:f7 disabled=no mac-address=\
    00:0A:CD:1B:71:F7 server=dhcp1
add address=10.10.0.105 client-id=1:0:1f:bc:2:66:4a disabled=no mac-address=\
    00:1F:BC:02:66:4A server=dhcp1
add address=10.10.0.111 disabled=no mac-address=00:02:B3:A9:E4:07 server=\
    dhcp1
add address=10.10.0.0/24 comment="default configuration" dns-server=10.10.0.1 \
    gateway=10.10.0.1 netmask=23
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=512 servers=8.8.8.8,8.8.4.4
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=drop chain=input comment="Drop Invalid Conns" connection-state=\
    invalid disabled=no
add action=drop chain=input comment="drop ssh brute forcers" disabled=no \
    dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
    address-list-timeout=1w3d chain=input connection-state=new disabled=no \
    dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
    address-list-timeout=1m chain=input connection-state=new disabled=no \
    dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
    dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
add action=drop chain=forward comment="drop ssh brute downstream" disabled=no \
add action=add-src-to-address-list address-list="port scanners" \
    address-list-timeout=2w chain=input comment="Port scanners to list " \
    disabled=no protocol=tcp psd=21,3s,3,1
    address-list-timeout=2w chain=input comment="NMAP FIN Stealth scan" \
    disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
    address-list-timeout=2w chain=input comment="SYN/FIN scan" disabled=no \
    protocol=tcp tcp-flags=fin,syn
    address-list-timeout=2w chain=input comment="SYN/RST scan" disabled=no \
    protocol=tcp tcp-flags=syn,rst
    address-list-timeout=2w chain=input comment="FIN/PSH/URG scan" disabled=\
    no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
    address-list-timeout=2w chain=input comment="ALL/ALL scan" disabled=no \
    protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
    address-list-timeout=2w chain=input comment="NMAP NULL scan" disabled=no \
    protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="dropping port scanners" disabled=no \
    src-address-list="port scanners"
add action=drop chain=forward comment="dropping port scanners" disabled=no \
add action=drop chain=forward comment="Block Bogon IP addresses" disabled=no \
    src-address=0.0.0.0/8
    dst-address=0.0.0.0/8
    src-address=127.0.0.0/8
    dst-address=127.0.0.0/8
add action=accept chain=input comment="Allow WinBox" disabled=no dst-port=\
    8291 in-interface=ether1-gateway protocol=tcp
add action=accept chain=input comment="Allow DNS" disabled=no in-interface=\
    ether1-gateway protocol=udp src-port=53
add action=accept chain=input comment="Allow ICMP" disabled=no protocol=icmp
add action=accept chain=input comment="Allow Established Conns" \
    connection-state=established disabled=no in-interface=ether1-gateway
add action=accept chain=input comment="Allow New Conns" connection-state=new \
add action=accept chain=input comment="default configuration" \
    connection-state=related disabled=no in-interface=ether1-gateway
add action=accept chain=forward disabled=no in-interface=bridge \
    out-interface=ether1-gateway src-address=10.10.0.0/24
add action=accept chain=forward disabled=no dst-address=10.10.0.0/24 \
    in-interface=ether1-gateway out-interface=bridge
add action=accept chain=output disabled=no
add action=drop chain=input comment="Drop all" disabled=no in-interface=\
    ether1-gateway
add action=dst-nat chain=dstnat comment=SSH disabled=no dst-port=22 \
    in-interface=ether1-gateway protocol=tcp to-addresses=10.10.0.111 \
    to-ports=22
add action=dst-nat chain=dstnat comment=ZNC disabled=no dst-port=45000 \
    to-ports=45000
add action=dst-nat chain=dstnat comment=Terraria disabled=no dst-port=7777 \
    to-ports=7777
    in-interface=ether1-gateway protocol=udp to-addresses=10.10.0.111 \
    to-ports=7777
add action=dst-nat chain=dstnat comment="Mumble UDP" disabled=no dst-port=\
    64738 in-interface=ether1-gateway protocol=udp to-addresses=10.10.0.111 \
    to-ports=64738
add action=dst-nat chain=dstnat comment="Mumble TCP" disabled=no dst-port=\
    64738 in-interface=ether1-gateway protocol=tcp to-addresses=10.10.0.111 \
    to-ports=64738
add action=dst-nat chain=dstnat comment="OpenVPN TCP" disabled=no dst-port=\
    30000 protocol=tcp to-addresses=10.10.0.111
add action=dst-nat chain=dstnat comment="OpenVPN UDP" disabled=no dst-port=\
    30000 protocol=udp to-addresses=10.10.0.111
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    no out-interface=ether1-gateway
add action=log chain=dstnat disabled=yes log-prefix=""
add action=log chain=srcnat disabled=yes log-prefix=""
add action=dst-nat chain=dstnat comment=SRCDS disabled=yes dst-port=27015 \
    in-interface=ether1-gateway protocol=tcp to-addresses=10.10.0.105 \
    to-ports=27015
    in-interface=ether1-gateway protocol=udp to-addresses=10.10.0.105 \
    to-ports=27015
/ip firewall service-port
set ftp disabled=yes ports=21
set tftp disabled=yes ports=69
set irc disabled=yes ports=6667
set h323 disabled=yes
set sip disabled=yes ports=5060,5061 sip-direct-media=yes
set pptp disabled=yes
/ip hotspot service-port
set ftp disabled=no ports=21
/ip neighbor discovery
set ether1-gateway disabled=no
set ether2-local disabled=no
set ether3-local disabled=no
set ether4-local disabled=no
set ether5-local disabled=no
set bridge disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
    cache-on-disk=no enabled=no max-cache-size=none max-client-connections=\
    600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \
    parent-proxy-port=0 port=8080 serialize-connections=no src-address=\
    0.0.0.0
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ether1-gateway \
    pref-src=10.10.0.1 scope=30 target-scope=10
    pref-src=0.0.0.0 scope=30 target-scope=10
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=76.178.144.1 scope=\
    30 target-scope=10
/ip service
set telnet disabled=yes port=23
set ftp disabled=yes port=21
set www address=10.10.0.0/23 disabled=no port=80
set ssh disabled=yes port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=80
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=bridge type=internal
add disabled=no interface=ether1-gateway type=external
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=ethernet-default
set ether2-local queue=ethernet-default
set ether3-local queue=ethernet-default
set ether4-local queue=ethernet-default
set ether5-local queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
