4.6 broken packages?
Cant import routeros-mipsbe/le/powerpc into dude. Tried manually upgrading a test AP in our office and it says it is a broken package.
I have some problem, package 4.6 in broken, in all platforms.
Getting reports of this as well.
Also noting it looks like the torrents are not being seeded at all. Stuck at 50% all around.
Same here, broken packages… Seriously starting to wonder about Mikrotik. Do they do any quality testing?? This is second time I can remember this happening.
Same problem. x86 package broken
I have the same problem. I tried downloading it with torrent but torrent seems to hang after about 52%. I’ve downloaded both the 400 series and the Intel/AMD multiple times and get the same message on the PC and on a 450G " system,error broken package". I tried both http download from a browser and using the fetch command from inside the router. Is anyone having any luck installing 4.6?? :frowning:
I am downloading from the USA site, I tried the mirrors, but neither of them have the package. I also tried Canada, but they did not have the package either.
I’m installed ROS 4.6 on RB750g and updated firmware to 2.25. It’s ok :smiley:
Same problem here. If I get it I will throw it up on our webserver.
Hey folks, word is 4.5 works.
http://download.mikrotik.com/routeros-powerpc-4.5.npk
Giving it a try now.
4.5 works from the link above.
I’ve been using 4.5 for a while now and it works great, but I like to test before I deploy on production equipment. That’s why I was trying to upgrade, but I haven’t had any luck upgrading to 4.6. Other people seem to be ok, I’m wondering if it is the US site that is the problem. If I connect a console cable I can see that it gets about 3/4 of the way through the decompression and then aborts.
I wouldn’t worry about trying to get it to work.
Not our job.
At least they have enough error checking to verify the packages prior to trying to install them.
I’m sure MT will eventually fix it.
Until then, sit back and enjoy the train wreck.
What is the hurry ?
nz_monkey - none I guess
It’s just the typical IT stuff - hurry up and wait.
afaics, ‘Combined’ packages are broken. I upgraded my x86 and RB450G w/o problems with individual packages…
http://www.mikrotik.com/download/routeros-md5-4.6.txt
AFAIK only the torrent seed is broken, because somebody is manually seedin broken stuff, because MT seed is gone. Try HTTP
http broken also
worked well for me now
all should be fixed
