4 antenna dual polarization from point to point ?
I have a 4 antenna dual polarization
I would like to work all between two points
The question is
Is it possible to use it between two point with full readiness
Meaning
To be allocated to the card send sent from both sides at the same antenna
Or just sent by the part of only one of the dual-antenna
I will work on today and I want to answer as quickly as possible please
regards
am waiting gentleman
you want to use both polarizations of a dual polarized antenna for a point-to-point link?
does the antenna have two connectors? if yes, you can use it with Nstreme dual or with 802.11n (in RouterOS v4 only). These technologies need two cards in each end of the link, each card will be connected to one of the two connectors of your antenna.
