i need help with my network my problem is slow browsing and speedtest not get in all client.. is used bypass speedtest but same problem.. my isp is
ether1-1gb static
ether2-1gb static
ether3-800mbps dynamic
ether4-800mbps dynamic
can anyone helpme how to manage this… 4 isp with smooth browsing and speedtest.. i have pppoe server config on the router CCR2116 V7.
I think you should check the configuration of your PPPoE server on the CCR2116 V7 router. Ensure that it is properly set up with appropriate settings such as authentication, session limits, and queue types. You may need to adjust the settings based on the capacity of your ISP connections and the number of clients you have.
For any load balancing of your dynamic ISP connections you will need scripts to ensure the correct gateway is used in IP routes ( unless they are pppoe client connections).
