Hello Everyone,
We have 4 uplinks all using BGP to connect and 8 ppoe routers.
What is the best solution in this scenario?
Using one core router or any other solution please suggest.
Thank you.
Sent from my COR-AL00 using Tapatalk
Hello Everyone,
Thank you.
Hi!! Can you please help us with a drawing for that solution? I’m wondering if all of those PPPoE Servers are directly connected to the core router and you’re using iBGP as routing protocol between those routers??
