Hello everyone,
I’ve been having this annoying problem with CAPsMAN, though honestly on one device only (Raspberry Pi 4 on LibreELEC) but only when CAPsMAN is used. When i disable it and use regular interface RPi joins just fine.
I’ve tried many things
- basic configuration (will not connect at all)
- Disabling VHT Basic rates (will connect but 4way handshake timeout problem)
- Tried different rates
- Using wpa-psk with wpa2-psk (been using wpa2-psk only)
- Tried to make another device capsman
- Turning local forwarding and client forwarding on and off
- Different frequencies
- Different channels
I just don’t know what I’m missing. Below is current setup, any advice would be highly appreciated!
[admin@Hodnik-Gore] > caps-man export hide-sensitive
# feb/04/2022 09:50:27 by RouterOS 6.49.2
# software id = YUS8-7IKM
# model = RBcAPGi-5acD2nD
# serial number = F9AD0F3EFA80
/caps-man rates
add basic=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps name="24-rates no slowrates"
/caps-man access-list
add action=reject allow-signal-out-of-range=10s comment="Moj telefon" disabled=no mac-address=1C:CC:D6:4D:8B:E0 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Ljubicin Telefon" disabled=no mac-address=4C:F2:02:85:86:AA ssid-regexp=""
add allow-signal-out-of-range=10s comment="Pumpa za bazen" disabled=no mac-address=60:01:94:E5:92:C6 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Lenovo laptop" disabled=no mac-address=A4:C3:F0:CE:57:DE ssid-regexp=""
add allow-signal-out-of-range=10s comment=Stampac disabled=no mac-address=B4:B6:86:6E:8F:68 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Svetlo garaza" disabled=no mac-address=C4:DD:57:06:AC:66 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff - Spavaca Soba Svetlo" disabled=no mac-address=2C:F4:32:C3:0B:4E ssid-regexp=""
add allow-signal-out-of-range=10s comment="Kamera Gornja Terasa" disabled=no mac-address=30:FF:F6:3A:E7:AD ssid-regexp=""
add allow-signal-out-of-range=10s comment="Kamera Terasa" disabled=no mac-address=30:FF:F6:3A:E7:D3 ssid-regexp=""
add allow-signal-out-of-range=10s comment="NodeMCU DHT" disabled=no mac-address=50:02:91:C8:C8:86 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Garaza Svetlo Pec" disabled=no mac-address=60:01:94:C8:C2:06 ssid-regexp=""
add allow-signal-out-of-range=10s comment="NodeMCU IR Transciever" disabled=no mac-address=68:C6:3A:F8:D8:FA ssid-regexp=""
add allow-signal-out-of-range=10s comment="Dnevna Soba TV" disabled=no mac-address=80:9F:9B:ED:1F:E1 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Dnevna Soba Tablet" disabled=no mac-address=AE:B5:DA:30:A1:36 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Garaza Svetlo" disabled=no mac-address=D8:F1:5B:B3:B0:E4 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Spavaca Soba TV" disabled=no mac-address=D8:F1:5B:C6:E8:76 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Garaza Pec Na Pelet" disabled=no mac-address=D8:F1:5B:C8:01:A7 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Garaza Garazna Vrata" disabled=no mac-address=DC:4F:22:9E:55:11 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff - Prekidac za ruter" disabled=no mac-address=CC:50:E3:68:7F:F2 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff Zigbee Bridge" disabled=no mac-address=84:CC:A8:AA:2A:E7 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Sonoff - Uticnica 2" disabled=no mac-address=9C:9C:1F:89:82:D2 ssid-regexp=""
add allow-signal-out-of-range=10s comment="Roborock S5 Max" disabled=no mac-address=B0:4A:39:0A:D6:18 ssid-regexp=""
add allow-signal-out-of-range=10s comment=Joksa disabled=no mac-address=BA:E6:72:65:10:6A ssid-regexp=""
/caps-man configuration
add channel.band=2ghz-b/g/n channel.control-channel-width=20mhz channel.extension-channel=XX country=serbia datapath.bridge=bridge datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes guard-interval=any hide-ssid=no installation=indoor mode=ap multicast-helper=default name="CAPs Conf" \
rates.basic=12Mbps rates.supported=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps rx-chains=0,1 security.authentication-types=wpa2-psk security.encryption=aes-ccm security.group-encryption=aes-ccm ssid="Don't look at me" tx-chains=0,1
add channel.band=5ghz-onlyac channel.control-channel-width=20mhz channel.extension-channel=eCee country=serbia datapath.bridge=bridge datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes hide-ssid=no installation=indoor mode=ap name="CAPs Conf 5GHz" rx-chains=0,1 security.authentication-types=\
add channel.band=5ghz-onlyac channel.control-channel-width=20mhz channel.extension-channel=XX channel.frequency=5200,5220,5240,5745,5765,5785,5805,5825 channel.reselect-interval=1h channel.skip-dfs-channels=no country=serbia datapath.bridge=bridge datapath.client-to-client-forwarding=yes \
datapath.local-forwarding=yes datapath.vlan-id=1 datapath.vlan-mode=no-tag guard-interval=any hide-ssid=no installation=indoor mode=ap name="CAPs Conf 5GHz TEST" rates.vht-basic-mcs=none rates.vht-supported-mcs=mcs0-9,mcs0-9,mcs0-9 security.authentication-types=wpa2-psk security.encryption=aes-ccm \
/caps-man interface
add configuration="CAPs Conf" disabled=no mac-address=DC:2C:6E:8F:55:23 master-interface=none name=2.4-Hodnik-Gore-1 radio-mac=DC:2C:6E:8F:55:23 radio-name=DC2C6E8F5523
add configuration="CAPs Conf" disabled=no mac-address=74:4D:28:6D:4E:1D master-interface=none name=2.4-hAPac2-1 radio-mac=74:4D:28:6D:4E:1D radio-name=744D286D4E1D
add configuration="CAPs Conf 5GHz TEST" disabled=no l2mtu=1600 mac-address=DC:2C:6E:8F:55:24 master-interface=none name=5.0-Hodnik-Gore-1 radio-mac=DC:2C:6E:8F:55:24 radio-name=DC2C6E8F5524
add configuration="CAPs Conf 5GHz" disabled=no mac-address=74:4D:28:6D:4E:1E master-interface=none name=5.0-hAPac2-1 radio-mac=74:4D:28:6D:4E:1E radio-name=744D286D4E1E
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge
/caps-man provisioning
add action=create-enabled comment=5.0GHz hw-supported-modes=ac master-configuration="CAPs Conf 5GHz TEST" name-format=prefix-identity name-prefix=5.0 radio-mac=DC:2C:6E:8F:55:24
add action=create-enabled comment=2.4GHz hw-supported-modes=b,gn master-configuration="CAPs Conf" name-format=prefix-identity name-prefix=2.4 radio-mac=DC:2C:6E:8F:55:23
add action=create-enabled comment="5.0GHz - hAP ac2" hw-supported-modes=ac master-configuration="CAPs Conf 5GHz" name-format=prefix-identity name-prefix=5.0 radio-mac=74:4D:28:6D:4E:1E
add action=create-enabled comment="2.4GHz - hAP ac2" hw-supported-modes=b,gn master-configuration="CAPs Conf" name-format=prefix-identity name-prefix=2.4 radio-mac=74:4D:28:6D:4E:1D
add action=create-dynamic-enabled comment=2.4GHz hw-supported-modes=b,gn master-configuration="CAPs Conf" name-format=prefix-identity name-prefix=2.4
add action=create-dynamic-enabled comment=5.0GHz hw-supported-modes=ac master-configuration="CAPs Conf 5GHz" name-format=prefix-identity name-prefix=5.0
