Hi ,
I was just wondering if I use a dual core pc with 2gb ram , can it handle 40 mb bandwidth + 20 mb YouTube traffic for 200 ppoe user ? Please advice
Hi ,
if you use the compatible hardware then the answer is no
Thanks a lot reply. Can you please explain why no ? And if no than suggested hardware ? How about CCR1016-12S-1S?
Waiting to hear from you
Yes it can.
Thanks for your opinion, I was just confused that a dual core + gigabyte Ethernet can handle this much with router os or not. I’m shure CCR can handle much better .
I think you will find CHR (64-Bit) more stable
Also, adding some RAM helps
North Idaho Tom Jones
