4011 and 2.5Gbps SFP
Does anyone know if the SFP+ port on the 4011 router can sync at 2.5 Gbps?
My internet providers SFP syncs at 2.5Gbps for their 1 and 1.5Gpbs fibre to the home service.
Unfortunately the MikroTik SFP+ port on the 4011 router cannot sync at 2.5 Gbps. It can sync at 1 Gbps or 10 Gbps.
Not mean to jack the thread. But im having the same issue, but its a little different in my case.
My isp provide 155M Sfp module ( old tech) . it works fine with the media converter. When plugged into 4011, it shows no link. All pon tx rx were there, which mean it can read the optical line. The problem is the link betwee sfp and cpu. Is there a possible fix in sofware, or else, i have to find another router.
Ps: the same sfl module Worksop’s fine in rb3011. Got link and internet.
Do you know of any of the product lines that can Sync at 2.5Gbps?
Got the same problem, will contact Mikrotik support to understand if it’s something they can fix via software update…
Oh well, its gonna be a long wait if they decide to fix via software update if its even possible.
Im kinda wish for a way to link 100M base in sfp+ slot. Rb4011.
Rb3011 works with Sfp base 100 if disabled autonegotiation, and hard set 100M.
