411AH 4.9 Upgrade Problems
Is anyone else having problems after upgrading to 4.9? I cannot seem to upgrade the firmware on the board using the /system routerboard upgrade command anymore.
And I have the board set to run at 800mhz, but in winbox is only shows 680???
We have the same problem on 433AH after upgrade to 4.9 ROS. The upgrade bootloader is 2.26, but it isn’t upgradable. When I update and reboot than the current bootloader is 2.25. Is it a bug?
Set /system routerboard settigs set force-backup-bouuter=no
Try to upgrade your RouterBOARD version then.
Thanks, that worked.
Dan.
