411Ah problem
hi friends
i have 5 411 ah that have same problem.
when open router os via winbox for firest time i dont have any problem and i can add ip address to them
after reboot router the router reboot but i cant ping it again or i can open it via winbox putty and …and when i diconnect lan cable from port led is on too.
after net install i have this problem again.
what should i do ?
thanks all
Looks like address/routes misconfuguration. Remove the configuration and set it again from scratch. Then paste export here…
Don’t you use partitions, do you?
Partition?
I just use netinstall and did not use any thing else
what should i do for this?
after reset Some times connect with 10Mb some times 100Mb too
This is extremely pleasant and nice post…You shook posting it…Thanks a ton for posting it…!!!
do you have any idea…?!
Look for bulged capacitors on the board.
