We just got up a 43 mile PtP Dual Nstream with a -65 rssi and are getting around 10 megabit accross it. What are some key settings that can improve the bandwidth as far as Framer Policy, etc. etc. Also it says that it is connected at 45 mbits TX and RX.
45 or 48mbps ?
sorry, 48
Compression (depending on what sort of traffic)
framer best fit seeems to work well for me
Can you post your configurations for Nstream 2. I want to compare what I have set up. Thanks
What hardware are you using?
router board 532?
PC based?
Radios?
Freqs(2.4 or 5.x)?
I have a short link that gets 65mbps each way. But I am using 2.4 and 5.3 in turbo mode.
I’m using Framer Policy:exact size and Framer Limit:4000. And my tx/rx in -44 to -47
Oh, And I am also shooting thruogh 1 inch glass with mirror coating.
what hardware are you using on that link you have jober?
tks
Im using 2 RB532 and 4 R52 Cards. These go into 2 Dual Polarized 34.5 dbi 4 foot dishes. Can someone please post their configs for their dual Nstream.
I don’t know that the router board 532 is going to get you great speeds with dual Nstreme running on them. They are realy for APs and high end clients.
If you want a realy fast dual Nstreme link you are going to have to buy some beefier hardware.
Maybe over clocking will help a little.
[admin@PtP Via / WTC to Colo] > interface wireless nstreme-dual pri
0 R name=“nstreme1” mtu=1500 mac-address=00:15:6D:10:3D:F9 arp=enabled
disable-running-check=no tx-radio=wlan2 rx-radio=wlan1
remote-mac=00:15:6D:50:11:6C tx-band=2.4ghz-g tx-frequency=2412
rx-band=5ghz rx-frequency=5180 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
framer-policy=exact-size framer-limit=4000
[admin@AMD / Colo to WTC] > interface wireless nstreme-dual print
0 R name=“nstreme1” mtu=1500 mac-address=00:15:6D:50:11:6C arp=enabled
disable-running-check=no tx-radio=wlan1 rx-radio=wlan2
remote-mac=00:15:6D:10:3D:F9 tx-band=5ghz tx-frequency=5180
rx-band=2.4ghz-g rx-frequency=2412 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
